Running Audacity 2.1.2 via .exe installer
Windows 7 Home Premium (x64) Service Pack 1 (build 7601)
AMD 3.20 gigahertz AMD Phenom II X6 1090T 6 core
Board: ASUSTeK Computer INC. M4A88TD-M/USB3 Rev X.0x
As a hobby in order to learn how to manipulate digital audio, I use Audacity mostly to make what are essentially ringtones. Gotten to the point where I will often import multiple files, eithar FLAC or MP3’s. But each time I import, the metadata (Tag fields), are overlaid with the values, or lack of values, from the imported file. If I have set up non-standard Tag fields, they completely disappear.
Doubt if it exists, but is there a way to import WITHOUT altering existing tag fields? Bettar still, for my purposes, would be a means whereby each imported file retaigns its own, separate tag data. Perhaps a task can be added to the “To Do” list?
Thanks in advance…
