Resume recording after playing back project so far
Is it possible to pause an unfinished project, play back what you have recorded so far, and then continue recording from that point? When I do this, the playback begins again simultaneously with the ongoing recording. There is no problem pausing the recording and then resuming it. The problem lies only with having played it back.
Shift-R. Append Recording.
Or maybe you want to de-select:
Audacity > Preferences > Recording: [_] Playthrough (as many as you have). That should kill playback while you’re recording.
Thanks Koz, a very straightforward solution. :slight_smile:
