Resume playback in a project [SOLVED]
How to make the mark to continue to listen to a sound exactly or has arrived after close audacity ?
Sorry but I can’t understand what you are asking.
Try to describe what you are doing and what the problem is.
You can add a label then save a project.
Audacity plays from the editing cursor in saved projects. Audacity remembers the position of the editing cursor in saved projects, but not if you already saved changes to the project and then move the cursor.
ah ok big thanks please close topic
