salut , j’ai des fichiers wav que j’aimerais convertir en flac pour les tags . ma question est simple risque-t-on une perte de qualité . merci
FLAC est sans perte.
absolument sans perte (32 bit float,2cnx,96000hz) ?? c’est un morceau très cool , j’insiste , je veux un son pur
Sorry, I can’t explain in French.
FLAC is lossless for 16-bit or 24-bit.
32-bit float format PCM would need to be converted to 16 or 24 bit and that conversion would not be totally lossless, though the losses involved in converting from 32-bit float PCM to 24-bit FLAC would be insignificant. Current state of the art professional audio equipment is capable of up to 23 bit accuracy and the conversion from 32-bit float PCM to 24-bit FLAC can handle that degree of accuracy.
ok , thanks a lot steve
