I am using Windows 7 and Audacity 2.1.0.
I have two sets of files. File1, attached, is a recording of an audiobook chapter. For purposes of this operation, it is the “target file.” File2 contains short segments of dialogue in different character voices. It is the “source file.”
Within File1, I have created labeled regions for each of the sections where I read one of the character voices in my “normal voice.” I want to replace those regions with the character voice regions.
Within File2, I have created labeled regions for each of the segments in character voice. Each labeled region in File 1 corresponds to a similarly named labeled region in File 2.
(BTW, I recorded in this manner so that I would not have to continually switch between different voices and could maintain consistency throughout the book for each character.)
Now I want to replace each of the regions in File1 with its corresponding region in File2. So I select the labeled region by clicking on the label in File2, and copy it using Alt-Shift-C.
Then I go to File1…and here’s where I run into trouble. What I thought I could do was to select the corresponding labeled region by clicking on the corresponding label in File1, which appears to highlight the labeled region in both the audio track and the label track…and click Paste (Ctrl-V) and voila, the audio I had previously copied would replace the selected audio.
Sadly, it does not work as expected. Instead, it just pastes the last text I copied to the Windows clipboard into the selected label.
If I manually select the target region in the audio track of File1 and click Ctrl-V, it works fine. It pastes in the audio, adjusting the duration of the target region to the length of the source region, which is exactly what I want it to do. However, I have hundreds of regions I need to move in this way, and if I could just click on the label to select the target region, it would be a lot easier and faster than manually selecting the target region each time, especially for longer passages that would require horizontal scrolling.
Thanks in advance,
David
