Replace "Cross Fade In" and "Cross Fade Out" effects
I think that we all like things to do what they say on the tin.
The “Cross Fade In” and “Cross Fade Out” effects do not perform cross-fades and IMO should be replaced by an effect that does.
I would like the “Cross Fade In” and “Cross Fade Out” effects to be replaced with this (one) Cross-Fade effect: https://forum.audacityteam.org/t/cross-fade-revisited/21408/1 (or something much like it).
This effect includes the functionality of both “Cross Fade In” and “Cross Fade Out”, and more importantly it can do a cross-fade.
+1 yes I like clearly labelled tins …
see reply to https://forum.audacityteam.org/t/cross-fade-revisited/21408/1
+1 way better than current offering
Steve does your recent work on a plugin for this negate the need to move this to the Feature Requests page later - i.e. is it already “Work In Progress”?
Yes it is a work in progress.
OK - moving it to Audio Processing section.
