I have an mp3 file of a voice that says “Hellllooo” once. I used the ‘Repeat’ effect and it worked well BUT I want to have a pause between each “Helllooo”. Is there a way to do that? (It’s for a ringtone)
When you select the “Hello”, include some silence after the “Hello” in the selection.
Thank you, Steve. How do I do that?
Click and drag with your mouse along the waveform:
Thanks Steve. I’ll try that later today.
