Is there a way to remove effects that come with Audacity and are no longer needed after adding vst plugins?
If you are using the current Audacity 2.1.1, use “Manage” to disable the effects that you don’t want.
http://manual.audacityteam.org/o/man/effect_menu.html#manage
I’m still on 2.0.9 and will download 2.1.1.
