Removing Noise Reduction Filters From Saved Files
Hi, I have saved some files that I used noise reduction on the files. The recipient has asked me to remove this as they want the raw file. But I can’t seem to find any way of doing it. any suggestions?
You can’t put the original noise back. It’s gone. (Unless you saved an Audacity Project AUP3 file, then undo may work.)
…You also can’t remove any artifacts/side-effects left-behind by the noise reduction. :frowning:
