I’ve got Audacity 2.x on windows 8.
I need some help cause i would like to remove some wind on my tape. I tried differents things such High pass filter, noise reduction, with no success…
Have you got some ideas ?
I can upload my small mp3 if it helps
Thanks a lot in advance !
There’s not a lot you can do with that. You may be able to make it sound a little less bad by using the “high pass filter” to remove some of the “boom” but basically the recording is too badly damaged to make much improvement.
