Hi,
I am a Windows 7 Audacity 2.0.3 user.
I would appreciate your help for the following scenario.
We do a recording everyday year round. During the months April thru October the ceiling fans adds noise to our recording. We like to remove ceiling fan noise. I am able to optimize noise removing parameter with minimum side effect as follows.
Noise reduction (dB): 12
Sensitivity (dB): 0.00
Frequency smoothing (Hz): 500
Attack/decay time (secs): 0.11
What I am doing is as follows -
First select (mark) Noise Profile in the file. We can assume this will be constant for all months April–October.
Then select ‘Effects’ menu, then then select ‘Noise Removal’ then click ‘Get Noise Profile’, do ‘Ctrl+A’ followed by ‘Ctrl+R’.
Is there any easy way to input Noise Profile as a constant from an external source rather than selecting (marking) from the file being processed for Noise removal everyday?
Is it possible to automate the process so that a Dummy can remove noise just by a click on a short-cut? Thanks.
Regards and Best Wishes,
Anami Bhargava
