Regular Interval Labels no longer appears to work
Regular interval labels no longer appears to work. After entering parms, get window labeled “Debug Output” with number of labels to be created and interval in seconds. After pressing OK, there are no labels created and no further messages.
Audacity 3.4.2 64bit
Commit Id: 9dd60f of Thu Nov 16 14:58:21 2023 +0300
Build type: CMake Release build (debug level 1), 64 bits
Compiler: MSVC 19.37.32825.00
Windows 11 Professional V23H2
System: Dell XPS 8950
___RIL pix
Testing on W10 with 3.4.2
I cannot reproduce this p works fine for me.
Peter
It’s a bug. Nyquist plugins that return labels fail if the selection also includes a label track · Issue #5648 · audacity/audacity · GitHub
The bug has been labeled as “P4” on a scale of 1 to 5, where P1 is highest priority and P5 is lowest.
The workaround is to ensure that no label tracks are selected when using effects that return labels. Unfortunately this also means that you can not use plugins to add labels to an existing label track - a new label track must be created each time or else Audacity fails to create the new labels.
