Hi I have looked around the forum and have not found an answer for my query so here goes. I hope someone can help please. I have sever Dyslexia so apologies if i have missed a relevant post.
Audacity Version 2.0.05. I am running Windows 7 32 BIT. I have a Focusrite Saffire LE soundcard and I am recording vinyl.
I am not sure which Host I should use. I don’t really understand the Audio Device Log.
In Audacity I have a choice of Hosts - MME or WindowsDirectSound (I believe that Windows WASAPI won’t work for my needs).
Questions:
- Looking at the Audio Device Log below, which is the lowest latency? MME or WindowsDirectSound?
For the MME Host the Low Input Latency / Low Output Latency is always the same (0.09). And High Input Latency / High Output Latency is always the same (0.18).
However for WindowsDirectSound Host the Low Input Latency is 0.12 (low output 0.0). And the High Input Latency is 0.240000 (high output 0.0). (SaffireLE Input 3/4)
Similarly for WindowsDirectSound Host the Low Output Latency is 0.12 (low input 0.0). And the High Ouput Latency is 0.240000 (high input 0.0). (SaffireLE Input 1/2)
What is the difference between Low Input Latency and High Input Latency?
Will the Host I choose affect the sound quality?
I was using XP and Audacity 1.2.6 but have now upgraded to W7. Is there any reason why the sound level being picked up by Audacity 2.0.5 is now a 2-3 DB quieter than it was with my old set up? I have checked the sound settings in the control panel and they are on and up to 100%
The only other change has been I have to use the legacy drive on W7 for the Soundcard. Doesnt appear to be any issues there. Can driver affect the input levels?
Please help. Thanks Paul
AUDIO DEVICE LOG
Default capture device number: 1
Default playback device number: 3
[color=#000000]Device ID: 0
Device name: Microsoft Sound Mapper - Input
Host name: MME
Input channels: 2
Output channels: 0
Low Input Latency: 0.090000
Low Output Latency: 0.090000
High Input Latency: 0.180000
High Output Latency: 0.180000
Supported Rates:
Device ID: 1
Device name: SaffireLE Input 3/4 (Focusrite
Host name: MME
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 2
Device name: Microsoft Sound Mapper - Output
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 3
Device name: SaffireLE Output 1/2 (Focusrite
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 4
Device name: Digital Audio (S/PDIF) (High De
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000[/color]
[color=#0000FF]Device ID: 5
Device name: Primary Sound Capture Driver
Host name: Windows DirectSound
Input channels: 2
Output channels: 0
Low Input Latency: 0.120000
Low Output Latency: 0.000000
High Input Latency: 0.240000
High Output Latency: 0.000000
Supported Rates:
Device ID: 6
Device name: SaffireLE Input 3/4 (Focusrite SaffireLE WDM)
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 7
Device name: Primary Sound Driver
Input channels: 0
Output channels: 2
Low Input Latency: 0.000000
Low Output Latency: 0.120000
High Input Latency: 0.000000
High Output Latency: 0.240000
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 8
Device name: SaffireLE Output 1/2 (Focusrite SaffireLE WDM)
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 9
Device name: Digital Audio (S/PDIF) (High Definition Audio Device)
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000[/color]
Device ID: 10
Host name: Windows WASAPI
Input channels: 0
Output channels: 2
Low Output Latency: 0.003000
High Output Latency: 0.010159
Supported Rates:
44100
Device ID: 11
Device name: Digital Audio (S/PDIF) (High Definition Audio Device) (loopback)
Input channels: 2
Output channels: 0
Low Input Latency: 0.003000
High Input Latency: 0.010159
Supported Rates:
Device ID: 12
Input channels: 0
Output channels: 2
High Output Latency: 0.010000
Supported Rates:
44100
Device ID: 13
Device name: SaffireLE Output 1/2 (Focusrite SaffireLE WDM) (loopback)
Input channels: 2
Output channels: 0
High Input Latency: 0.010000
Supported Rates:
Device ID: 14
Input channels: 2
Output channels: 0
Supported Rates:
Selected capture device: 1 - SaffireLE Input 3/4 (Focusrite
Selected playback device: 3 - SaffireLE Output 1/2 (Focusrite
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Available mixers:
Available capture sources:
0 - Master
Available playback volumes:
0 - PCM
Capture volume is native
Playback volume is native
