I’m not new to Audacity, but not an expert either. I’ve recorded tracks, edited them, compressed them. Normalised to minus 1db. No clipping. Sound great. I export them to save them. I then re-open them the next day,..the wav form is riddles with vertical red peak lines! And some wavs that were perfect when saved are now flat topped…. as if I had used a Limiter, which I didn’t. Please can anyone explain this? a waste of tow days work! Thanks all. You might prevent a suicide!
Hi DVD Doug. Thanks. I record at 48khz, (not 44.1) , and in 32 bit float. I import those wavs into Audacity; my Aidacity settings are matched at 48khz, and 32bit float. My “Quality” settings ( in Audacity “ preferences) are set at “Best/Slowest”. I really do not understand what is wrong; it is a day of work wasted each time. The file on screen looks perfect, and I normalise to minus 1db; I then listen of course before expeoring the file to save it. No prob. I then open it next day to work on it, and the wav is covered in vertical red lines, peaks. So I dont get it at all. I can only think that when Auadicty RE-imoirts it is somehow corrupting it and boosting it?? I am very careful to work at “best” quailty always. The ONLY poyher possibility I can think of is that Audacity is corruopting it DURING the exprotinging process, but as I say all my settings are for it to be saved exactly as it should be. (If I had a second editing programme I could oepn it in THAT, to see if it is only Audacity causing this; otherwise…what? My computer?? Thanks for your input, but I’m sure it is n’t me being mean with the quailty. oh! I also checked the volume to the left of the file, good point. I dont usually mess with them but just looked and they are all on 0.db; no boost. I’m only exproting three tracsk too; one is vocal. the other two are from X/Y precision mic’s on the guitar, so it is not a complex mix. Best wishes, Steve
You don’t say anywhere what type of file you are exporting the audio to. If you are saving the audio to a FLAC file, it will be converted to 24-bit, which will increase the likelihood of clipping, which is what I observed in the other thread of posts.
If you are saving the audio to a format that is 32-bit float, there is some other reason for the “clipping” that you are observing.
That being said, 32-bit float has enough headroom to store the sound of a supernova, if equipment is ever created that could do that. The red you are seeing in the waveform is potential clipping that could happen when the sound comes out of a speaker.
None of this information solves your problem of why the audio you exported is not the same when you import it back again.
Hi. Tha’s me only ever doign what I do and having blinkers on. I always export as “wav/microsoft”, and at the 48Khz and 32bir float setting. . Ive no experience of using Flac or Oggs, Ac3s, etc. I ‘m not vastly techy, but Ive obly experted as Wav as I knoew it was better than MP3, or I will sometimes expert as MP3 329 KBps if I am sending something by email and I want a smaller file. So basically I am recording a Wav, 48Khz, 32 bit float on my Zoom H6 recorder. Then I get that to Audacity for tweaks, compression, normalise etc. T
I always edit and play back using my AKG K612Pro headphones, or occassionallythe closed back version for comparison. hen always play back as I edit. When happy with the sound I then export still as wav, 48, 32, and think “I’ll carry on with that tomorrow”. When I re-open the red lines are there. Worse, despite me using 32 bit float, when I then highlight the track and “reduce amplification by a acouple of DB to “tame” it again and get rid of th ered lines, the wav form is then sometimes Flat topped! So when I then listen to it in my headphones those now flattened peaks show digital noise, and I cannot rescue it. I have to then get the original recorded wavs , and start all over again. As I say I am no Great Expert, but nonehtless I have been recording my stuff, either at home or my live gigs, always as Wav, (although only as 32 bit float for a year now as my old gear didnt do that) and I have sent the end product and had it played on radio, and by the BBC etc, and I have truly never come across this problem before. It;s probably, compared to many people, pretty much “ the basics” ; and when I am recording live it is just me singing with guitar, maybe 4 minute somngs at the most, so no multiple tracks to confuse the issue. It SHOULD… be simple. But suddenly it isnt. If I hadnt been doing this succesfully for years I’d be more convinced it is just me and my ignorance ( it could still be I suppose;!) but as I say it’s not been an issue before. If you save a file that sounds good, mp3 or wav or whatver, it should surely re-open in the same as you saved it, so you can carry own with the work. I am baffled. It might be the laptop even, as I seem to be running out of Audacity options! I hope not of course. Thanks again; yes I should have mentioned that I only use Wav, if that helps. Best wishes again, Steve
Like I said, mixing is done by summation so the volume will increase.
Audacity works in 32-bit float so Audacity itself won’t clip. But you CAN clip your DAC (digital-to-analog converter) if you play at “full digital volume”.
One work-around is to export as 32-bit floating point WAV, which has no upper (or lower limits). Then re-import and normalize before exporting as your final desired format. It will “show red” when you import but it’s not actually clipped.
Your ADC (analog-to-digital converter (probably) doesn’t support floating point so will clip at 0dB. It’s normal for Audacity to convert that to 32-bit float.
