hello
please see attachement
i have this massage appairing each time a load Adacity
i tried maies manipulations including re- installing Audacity still there !
do you have an idea
thanks
j’ai ce message qui apparait , que je ne peux effacer , il re-apparait a chaque " loading "
j’ai essayes multiples manipulations , y compris complete re-installations .
avez vous une idee
merci
maybe this is usefull to resolve this case
peut etre ces informations sont importante pour resoudre le problem
17:28:21: Audacity 2.0.5
17:28:21: Trying to load FFmpeg libraries…
17:28:21: Trying to load FFmpeg libraries from default path, ‘/Library/Application Support/audacity/libs/libavformat.52.dylib’.
17:28:21: Checking for monolithic avformat from ‘/Library/Application Support/audacity/libs/libavformat.52.dylib’.
17:28:21: Error: dlopen(/Library/Application Support/audacity/libs/libavformat.52.dylib, 1): image not found
17:28:21: Loading avutil from ‘/Library/Application Support/audacity/libs/libavutil.50.dylib’.
17:28:21: Error: dlopen(/Library/Application Support/audacity/libs/libavutil.50.dylib, 1): image not found
17:28:21: Loading avcodec from ‘/Library/Application Support/audacity/libs/libavcodec.52.dylib’.
17:28:21: Error: dlopen(/Library/Application Support/audacity/libs/libavcodec.52.dylib, 1): image not found
17:28:21: Loading avformat from ‘/Library/Application Support/audacity/libs/libavformat.52.dylib’.
17:28:21: Error: Failed to load FFmpeg libraries.
17:28:21: Trying to load FFmpeg libraries from legacy path, ‘/usr/local/lib/audacity/libavformat.52.dylib’.
17:28:21: Checking for monolithic avformat from ‘/usr/local/lib/audacity/libavformat.52.dylib’.
17:28:21: Error: dlopen(/usr/local/lib/audacity/libavformat.52.dylib, 1): image not found
17:28:21: Loading avutil from ‘/usr/local/lib/audacity/libavutil.50.dylib’.
17:28:21: Error: dlopen(/usr/local/lib/audacity/libavutil.50.dylib, 1): image not found
17:28:21: Loading avcodec from ‘/usr/local/lib/audacity/libavcodec.52.dylib’.
17:28:21: Error: dlopen(/usr/local/lib/audacity/libavcodec.52.dylib, 1): image not found
17:28:21: Loading avformat from ‘/usr/local/lib/audacity/libavformat.52.dylib’.
17:28:21: Trying to load FFmpeg libraries from system paths. File name is ‘libavformat.52.dylib’.
17:28:21: Checking for monolithic avformat from ‘libavformat.52.dylib’.
17:28:21: Error: dlopen(libavformat.52.dylib, 1): image not found
17:28:21: Loading avutil from ‘libavutil.50.dylib’.
17:28:21: Error: dlopen(libavutil.50.dylib, 1): image not found
17:28:21: Loading avcodec from ‘libavcodec.52.dylib’.
17:28:21: Error: dlopen(libavcodec.52.dylib, 1): image not found
17:28:21: Loading avformat from ‘libavformat.52.dylib’.
17:28:21: Error: Failed to find compatible FFmpeg libraries.
17:28:37: Error: Could not parse file “/Users/peter/Library/Application Support/audacity/AutoSave/B Chapitre VIII master) :1 - 2014-01-30 14-17-31 N-14.autosave”.
Error: Could not load file: “/Users/peter/Library/Application Support/audacity/AutoSave/B Chapitre VIII master) :1 - 2014-01-30 14-17-31 N-14.autosave”
17:28:54: Error: Could not parse file “/Users/peter/Library/Application Support/audacity/AutoSave/B Chapitre VIII master) :3 - 2014-01-30 14-33-14 N-16.autosave”.
Error: Could not load file: “/Users/peter/Library/Application Support/audacity/AutoSave/B Chapitre VIII master) :3 - 2014-01-30 14-33-14 N-16.autosave”
17:29:11: Error: Could not parse file “/Users/peter/Library/Application Support/audacity/AutoSave/B Chapitre VIII master): 2 - 2014-01-30 14-20-40 N-11.autosave”.
Error: Could not load file: “/Users/peter/Library/Application Support/audacity/AutoSave/B Chapitre VIII master): 2 - 2014-01-30 14-20-40 N-11.autosave”
17:29:33: Attempting to load LAME from previously defined path
17:29:33: Loading LAME from /Users/peter/Music/a:Music appl-fldr/Audacity-fldr/libmp3lame.dylib
17:29:33: Error: dlopen(/Users/peter/Music/a:Music appl-fldr/Audacity-fldr/libmp3lame.dylib, 1): image not found
17:29:33: load failed
17:29:33: Attempting to load LAME from system search paths
17:29:33: Loading LAME from libmp3lame.dylib
17:29:33: Error: dlopen(libmp3lame.dylib, 1): image not found
17:29:33: Attempting to load LAME from builtin path
17:29:33: Loading LAME from /usr/local/lib/audacity/libmp3lame.dylib
17:29:33: Error: dlopen(/usr/local/lib/audacity/libmp3lame.dylib, 1): image not found
17:29:33: (Maybe) ask user for library
17:29:33: Failed to locate LAME library
STOP !
i do not understand why but the problem dissppear !!!
je ne comprends pas pourquoi mais le probleme a disparut !!!
anyway thanks / merci
Please see here for what happens if there is a crash and Audacity offers to recover projects: http://manual.audacityteam.org/o/man/recovery.html .
From your log, there seem to be colons in file and folder names. I don’t know if that happened because you used a forward slash and Audacity translated it to a colon, or you actually tried to use colons, but you cannot use colons in file and folder names on OS X.
It’s much better not to use forward slashes either, unless the files are going to stay on your own computer all the time. If the files are to be sent to others or distributed on the internet, only use A to Z or a to z characters, whole numbers (0 to 9), underscore or hyphen-minus (or use the NUMPAD_SUBTRACT key). This will ensure the file name will always be compatible.
