Records but screen is blank
On my pc I can record audio but my screen is blank. Is this normal? Or is there a setting that may be turned off? Audacity recording and playback screens are normal on my other pcs - however the blank screen on this device makes it difficult to navigate
You don’t mention what operating system you are using. This sounds like what happens when the program is running on another monitor. While it is rare, it is possible the computer thinks it has more monitors than it actually has. Fixing it depends on the operating system.
This is on an acer pc with windows 10 as the operating system
Right-click on any blank space and select Display Settings, then click on Identify. If there is a non-existent monitor, disable it, then re-open Audacity. Just rebooting your computer may do the same thing for you.
Thx 4 the advice but no luck. Screen is still blank even though it says it’s recording. Weird - I have audacity on 3 desktop pcs - and works fine. For some reason it just won’t work on this Acer laptop.
Does Audacity work differently on PCs and laptops? Curious.
