Running Linux Mint 15 with Audacity 2.03-1. A 100 second recording plays back in 43.5 seconds. In addition to the pitch being far too high, the recording appears to be full of holes or dropouts. The 440 hz test tone records and plays back properly. I also use the latest version of Audacity on Windows XP with no problems. Windows and Linux utilize the same audio devices.
Moved to Linux forum.
Please give exact steps to reproduce the problem (I can’t see your computer )
Phono preamp feeds Sound Blaster Live 5.1 SB0060 sound card, which uses ALSA generic drivers. Processor runs at 2.93 GHZ.
Steve:
Sorry, but I will be away from the affected computer for about 3 weeks. Will get back to you after that.
Ken
Devices selected are ALSA, SB Live! 5.1 (SB0060), SB Live! 5.1 (SB0060):Multi and 2(Stereo) In
What is the output of “Help > Audio device info” (copy and paste the full contents of the information box)
Default capture device number: 16
Default playback device number: 16
Device ID: 0
Device name: SB Live! 5.1 [SB0060]: ADC Capture/Standard PCM Playback (hw:0,0)
Host name: ALSA
Input channels: 2
Output channels: 2
Low Input Latency: 0.011610
Low Output Latency: 0.011610
High Input Latency: 0.046440
High Output Latency: 0.046440
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
Device ID: 1
Device name: SB Live! 5.1 [SB0060]: Mic Capture (hw:0,1)
Host name: ALSA
Input channels: 2
Output channels: 0
Low Input Latency: 0.064000
Low Output Latency: -1.000000
High Input Latency: 0.256000
High Output Latency: -1.000000
Supported Rates:
Device ID: 2
Device name: SB Live! 5.1 [SB0060]: Multichannel Capture/PT Playback (hw:0,2)
Host name: ALSA
Input channels: 16
Output channels: 2
Low Input Latency: 0.010667
Low Output Latency: 0.010667
High Input Latency: 0.042667
High Output Latency: 0.042667
Supported Rates:
48000
Device ID: 3
Device name: SB Live! 5.1 [SB0060]: Multichannel Playback (hw:0,3)
Host name: ALSA
Input channels: 0
Output channels: 16
Low Input Latency: -1.000000
High Input Latency: -1.000000
Supported Rates:
48000
Device ID: 4
Device name: sysdefault
Host name: ALSA
Input channels: 128
Output channels: 128
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
Device ID: 5
Device name: front
Host name: ALSA
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
Device ID: 6
Device name: rear
Host name: ALSA
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
Device ID: 7
Device name: center_lfe
Host name: ALSA
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
Device ID: 8
Device name: surround40
Host name: ALSA
Input channels: 0
Output channels: 4
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
Device ID: 9
Device name: surround41
Host name: ALSA
Input channels: 0
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
Device ID: 10
Device name: surround50
Host name: ALSA
Input channels: 0
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
Device ID: 11
Device name: surround51
Host name: ALSA
Input channels: 0
Output channels: 6
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
Device ID: 12
Device name: iec958
Host name: ALSA
Input channels: 0
Output channels: 2
Supported Rates:
48000
Device ID: 13
Device name: spdif
Host name: ALSA
Input channels: 16
Output channels: 2
Supported Rates:
48000
Device ID: 14
Device name: pulse
Host name: ALSA
Input channels: 32
Output channels: 32
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 15
Device name: dmix
Host name: ALSA
Input channels: 0
Output channels: 2
Low Output Latency: 0.042667
Supported Rates:
48000
Device ID: 16
Device name: default
Host name: ALSA
Input channels: 32
Output channels: 32
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Selected capture device: 2 - SB Live! 5.1 [SB0060]: Multichannel Capture/PT Playback (hw:0,2)
Selected playback device: 2 - SB Live! 5.1 [SB0060]: Multichannel Capture/PT Playback (hw:0,2)
Supported Rates:
48000
Available mixers:
Available capture sources:
0 - Line:0
1 - CD:0
2 - Mic:0
3 - Video:0
4 - Phone:0
5 - Aux:0
6 - Mix:0
7 - Mix Mono:0
Available playback volumes:
0 - Master:0
1 - Headphone:1
2 - Bass:0
3 - Treble:0
4 - 3D Control Sigmatel - Depth:0
5 - 3D Control Sigmatel - Rear Depth:0
6 - PCM:0
7 - Front:0
8 - Surround:0
9 - Center:0
10 - LFE:0
11 - Synth:0
12 - Wave:0
13 - Wave Center:0
14 - Wave LFE:0
15 - Wave Surround:0
16 - Line:0
17 - Line LiveDrive:0
18 - Line2 LiveDrive:1
19 - CD:0
20 - Mic:0
21 - Video:0
22 - Phone:0
23 - IEC958 Coaxial:0
24 - IEC958 LiveDrive:0
25 - IEC958 TTL:0
26 - Beep:0
27 - Aux:0
28 - AC97:0
29 - Sigmatel Surround:0
Capture volume is native
Playback volume is native
None of the default input devices give any indication on the input level meter.
OK, but does Audacity play correctly when the defaults are selected? Try importing an audio file or generate a click track.
The only working input is: SB Live! 5.1 (SB0060) Multichannel Capture/PT Playback (hw:0.2) Line:0
If you do not already have it installed, install “pavucontrol” (PulseAudio Volume Control).
Ensure that no other audio programs are running - particularly ensure that you have no web pages open that contain sound.
Open Audacity and set both the recording and playback devices to “Pulse”.
Import a long audio file and start playing.
If sound is not heard, open pavucontrol while Audacity is playing and look in the “Playback” tab. Audacity should be listed and there should be an option to select which output to use and playback level.
pavucontrol installed and recording and playback devices set to Pulse. No input. Screenshot attached.
/home/kenneth/Desktop/Screenshot-1.png
Use the “upload attachment” option below the message composing box.
Sorry about that.
However, I think we’re on the wrong tack here. The problem seems to be time compression. A recording with a real time length of 3:35 is displayed as 1:36 as indicated by the time shown above the waveforms. The waveforms show very visible time compression. When played back, it does not appear that the pitch has changed. The sound is what you would hear if the phono stylus rapidly skipped grooves during playback. Since I monitor the music while recording, I know that is not the case.
So which is it? The pitch is too high on playback or not too high?
I believe the pitch is correct. The playback skips so badly that I at first thought the pitch was higher. My apologies for the confusion.
OK, so if you generate a 30 second 440 Hz tone, does it play back smoothly as a constant tone for 30 seconds?
While it is playing, what shows on the “Playback” tab in pavucontrol?
Yes, it plays back smoothly at a constant tone.
