recording
what are the settings for djing? what i have tot change in audiocity? Because i hear a lot noise when i record…
Thank you for your help guys
Not enough information.
What are you trying to record?
What equipment are you using?
How is it all connected together?
What settings are you currently using?
i record my djing set. i play on cjd 2000 pioneer nexus. The cables i put two in record out and the other one in my pc. the settings are normale. i did’nt change something.
See here: https://forum.audacityteam.org/t/recording-solved/31909/1
Please don’t double post the same question.
