recording
Recorded one side of album. Stopped recording. Turned LP over and restarted recording. Thought recording would continue on same line. Instead a parallel row was created below for side B. Both rows label and play as if one side. I cannot highlight one row to drag away!
Drag the second track to the right using the Time Shift tool.
What you should have done in order to continue recording on the same track is “Append Record” (SHIFT + R). See here: http://manual.audacityteam.org/o/man/transport_menu.html#append
Where do I find the “Time Shift Tool”?
See this page in the Manual: http://manual.audacityteam.org/o/man/tools_toolbar.html
By the way, “Append Record” is Shift+r.
The Slide or Time Shift tool is F5 (F1: back to the Selection tool).
