Recording via USB Audio Codec
I work on an iMac 21", Yosemite 10.10. When I make a recording on Audacity, I can see the recording but I can’t get an output? How do I do that? I have tried to use “Internal Speakers” and “USB Audio Codec” as output without result!
So you get the bouncing sound meters and blue waves, right?
Not enough info. What are you recording and how?
If you are trying to listen to the recording as you make it, try Transport > Software Playthrough or Transport > Hardware Playthrough in the Audacity menu bar (but the hardware playthrough is not likely to work on such a modern Mac). If that does not work, get LineIn from Rogue Amoeba.
If USB Audio CODEC is a USB turntable or cassette deck, you cannot send computer playback to it. Choose the built-in speakers for output.
