Recording Streaming Audio on the Computer
I am using Windows 11
Audacity 3.2.3
I think that the recording of streamed or what’s on your computer audio is great concept, however I’m having
an issue using with the suggested method… WASAPI - SPEAKERS (Loopback) - Speakers Realtek Audio… I just
can’t get it started using this method…However one of my sound cards does start but seems to stop… after
resetting the WASAPI and my soundcard playback it starts again most of the time…any suggestions ?
Roger
WASAPI only starts recording if there is a signal to record. (i.e. stops recording if there is no signal).
If you have stereo Mix option , (instead of WASAPI), that will record when there is no signal.
https ://manual.audacityteam.org/man/tutorial_recording_computer_playback_on_windows.html
