Recording Stops After One Minute
I’ve been using Audacity for years without problems, but today, all of a sudden, the recording stops after a minute. It’s not frozen, it’s not set to “Sound Activated Recording”, but it will stop at exactly the same length of time every time.
But when I disconnected my USB microphone, the problem went away, why would this suddenly become a problem? It’s the same mic I’ve had for a year now. I can’t record with anything else, I’m stuck.
There was a similar post recently where someone had accidentally turned on looping. Could it be something as simple as that?
Mark B
Thanks for the suggestion. That doesn’t seem to be it. Managed to record the episode of my podcast in the end. All I changed was the USB port I was plugging the mic into. No idea why that made a difference, the first port is fine.
I’m glad you found some sort of solution.
Mark B
