At the moment when I record audacity takes the sound from both my sound card and my built in mic.
I have tried turning down the mic volume, but then it turns the sound card volume down too.
This is probably a stupid question, but as I said in my other post I am new to MACs. Can anyone help?
thanks
If you want to record what the sound card is playing without room noise, install Soundflower thus:
http://manual.audacityteam.org/o/man/tutorial_recording_computer_playback_on_mac.html .
Ok I have installed it and set it up and it works so thanks for that.
One minor issue, is the level seems to be low. How do I make the level higher using soundflower?
Thanks
