Newtime user. Don’t know if question got posted. Trying to record old cassettes using headphone jack to line-in. Only hearing out of one speaker. Can it get it to play out of both?
Audacity > Preferences > Devices > Recording > Channels > 2-Channel (Stereo).
Make sure your audio cable plug is all the way in.
Do you have two sockets like this?
http://www.kozco.com/tech/audacity/pix/MacLineIn.jpg
yes
That didn’t work. Still only hearing from one speaker.
Check your cable. Is it a 1/8" or 1/4" headphone jack? Do the plugs on both ends of the cable have three connections?
See: http://manual.audacityteam.org/man/How_to_connect_your_equipment
Note the first picture.
– Bill
They are mini jacks with two ridges. I believe they’re 1/8 (the same plug that goes into the “line-in” on the iMac.
Got it! I pushed both jacks in hard and it must not have been making a good connection, because now it works. Thanks!
Marked as solved.
