If you are working over several days on something I would recommend saving an Audacity Project (File > Save Project…). Then when you restart next day, just open the AUP file you saved.
For additional safety, you could File > Export… a WAV file after each recording, as a backup if something happens to the project. But it will be convenient to reopen the project.
When you reopen the project, you can hold SHIFT and click on Record to record at the end of the track that is already there.
