Hi guys
Bit of a newbie to all of this so bear with me.
I’ve recently acquired a Korg X-50 synth to write music on. I’ve got to the point now where I’d like to start experimenting with recording so downloaded Audacity on the recommendation of a friend.
My laptop (Toshiba) does not appear to have a line-in, so in attempt to record the sounds from the keyboard, I have run a cable from the Line-Out on the keyboard to the microphone slot on my laptop (using the relevant jack-plug).
The issue I have is that after 10-15 seconds or so of recording, the sound starts to cut out intermittently on the recording. I have a sneaking suspicion that the signal from the keyboard might be overloading the laptop (I read somewhere that the mic input on a laptop is usually very sensitive).
I have turned down the mic input volume to the lowest possible on the laptop but that doesn’t appear to have much effect. Is there any way around this? I guess the alternative is to buy a piece of hardware to get around this problem - is there any you guys can recommend? Looking back at this thread : https://forum.audacityteam.org/t/recording-problem-from-guitar-amp-to-laptop/20531/1 - which I think is a similar issue, a Behringer UCA-202 has been recommended to solve the problem.
Can anyone advise? Many thanks in advance
