Successful recording from Skype requires either, special software (such as Pamela, Total Recorder, etc,) or 2 computers.
The problem is that to record sounds playing on your computer you need to set the input to “Stereo Mix”, but to use Skype the input must be set to Microphone. Skype automatically takes over the sound card and sets the recording input to Microphone, which in turn means that Audacity cannot record properly from Skype.
Thanks for your response. Sorry about the incorrect posting.
I actually used a combination of Skype, Audio Repeaters, Audacity and Ustream on another computer and streamed successfully quite a few times.
The Stereo Mix option is not available on this computer which has Vista.
Once again, thanks for your prompt response. Sorry about the posting error.
