recording internet radio to IPOD
I have windows 10. my version on Audacity is 2.1.3
I am new to all this .
can someone tell me in easy steps how to record from a internet radio station to a IPOD. please make it easy steps.
thank you for your time.
Here’s the instructions on how to record internet streaming …
http://manual.audacityteam.org/man/tutorial_recording_audio_playing_on_the_computer.html
Then save (aka export) the audio-recording as a WAV file which can be played on any music-player, or computer.
Saving in MP3 format will produce much smaller audio files than WAV format,
but to save in MP3 using Audacity you have to install something called LAME into Audacity …
http://manual.audacityteam.org/man/faq_installation_and_plug_ins.html#[b]How_do_I_download_and_install_the_LAME_MP3_encode[/b]r.3F
The easiest way is to find out if the station has a podcast. If it does, install iTunes for Windows, download the podcast, create a playlist in iTunes, and pull it over to the iPod.
Can you put work on your iPod from Windows now? How do you do it?
See also: http://manual.audacityteam.org/man/tutorial_exporting_to_itunes.html
and: http://manual.audacityteam.org/man/sample_workflow_for_exporting_to_itunes.html
