Recording from Voice Recorder
Hi!
I have just installed Audacity and am able to record using my mike.
I have a digital voice recorder with no USB outlet. Is there any way I can record from my voice recorder to my PC?
Hope you can help.
Thanks
You can probably record the headphone output from the voice recorder using a suitable lead (stereo mini-jack) to connect it to a Line input on your computer. If your computer is a laptop PC you probably won’t have a Line-level input, in which case you would need to use the microphone input which is far from ideal, but may work at a pinch as long as you keep the playback volume from the voice recorder really low.
Cheers Steve, done that and it works fine, cheers. Bill
