Recording from turntable, very quiet and echoey
I am in the process of trying to record my old vinyl albums onto my laptop. I am using WIndows Vista and Audacity 2.0.6, I used the .exe file to install. I have my stereo system hooked up to my laptop via the record out on the amp, with the RCA jacks going inot an RCA-to-1/8th inch converter, which is then plugged into the chord that goes into my line-in on my laptop - it’s an HP dv4-1435dx. When I record using Windows Sound Recorder everything comes out perfectly, but it’s a hasssle using that because I have to stop and start each song separately (I don’t want to just record album sides). When i use Audactiy to record a song, the volume is very low and seems like there’s a lot of reverb as well. I used all the default settings. Is there some setting(s) I need to change to get the sound louder and not have so much reverb? I have the recording volume in Audacity all the way up.
Do you hear the dog barking, too? Chances are you are recording the laptop built-in microphone, not the turntable connection. You could also be recording Stereo Mix or one of the other self-recording connections. Do you like to record YouTube music? Then it may be this one.
http://manual.audacityteam.org/o/man/tutorial_copying_tapes_lps_or_minidiscs_to_cd.html
Scroll down to “How to connect your equipment.”
That’s good news! Audacity should be able to capture the same digital audio stream. You’ll just need to figure-out why the configuration is wrong.
Since you are getting good results (with Windows Sound Recorder) you may be OK… But most laptops only have mic-in and headphone-out. The information I found online could be wrong, but it says your computer has a mic input and two headphone outputs. Usually, you’ll get better results with a line input.
Thanks for the feedback. I assumed that since it worked OK for Sound Recorder the mic input would work fine for anything else. Sounds like that’s not the case. I went to the section for ‘connecting’, sounds like I need something that will convert to a line-in. Live and learn.
