Recording from Minidisc pauses between songs[SOLVED]
Hi,
I am currently recording tracks from my minidisc player into Audacity,the problem i have is some of the songs have a break between the verse and chorus of the song where there is silence. When this happens the audio counter stops after a few seconds and then starts again when the chorus starts which throws the timing out of sync.
How do you keep the audio counter going through these silent breaks?
Thanks
Gordon
Make sure Sound Activated Recording is not selected.
Edit → Preferences → Recording → Sound Activated Recording.
Turned off Sound Activated Recording as you suggested and this worked ok, no problems when recording, thanks for your help.
