Dear all,
Is it possible to record directly from iTunes? If so, how?
Many thanks,
Dave.
Dear all,
Many thanks,
Dave.
With the OLD iTunes (not streaming) you can directly open the digital audio file in Audacity so there’s no need to record it. In order to open M4A files you will need to have [u]FFmpeg installed[/u].
Or, if you’ve got OLD-OLD-OLD M4A files from when Apple used copy protection you WILL have to record them as they are played, as above.
