RECORDING DJ MIXES/SETS ON TRAKTOR PRO 3 SOFTWARE USING AUDACITY
Traktor Pro software doesn’t allows you to record your sets when using streaming tracks from beatport or beatsourcce. i use to do this on serato dj by using VIRTUAL CABLE DRIVER on audacity. but on traktor pro software, this isnt working. i have tried google but no luck
I JUST WANT TO RECORD MIXES (STREAMING TRACKS) ON TRAKTOR PRO SOFTWARE USING AUDACITY. CAN SOMEONE PLS HELP ME???
I’ve never used VAC but [u]WASAPI Loopback[/u] can usually record whatever is coming-out of your computer speakers.
can i use this to record my mixes from Traktor Pro software ???
I don’t think so. I think you need to use the audio recorder that is built into Traktor Pro. See: https://support.native-instruments.com/hc/en-us/articles/209571409-Recording-a-Mix-with-TRAKTOR-s-Mix-Recorder-VIDEO-
unable to record streaming tracks as i mostly use beatport to play my mixes on traktor
