Hello,
I am experiencing the following problem with Audacity:
I am trying to record the output from laptop speakers using the recording channel “Speaker (Realtek High Definition (SST)) (loopback)” and “Stereo - 2 recording channels”.
When recording for example the audio of a Youtube video with full audio volume, the maximum amplitude is very often reaching 0 dB (and most probably “more” than that, as the recording curves look like the “tips” of the curves are cut away… hope you understand what I mean ).
So what I was doing so far was to set the Youtube video audio volume control for example to 0.4 so that the maximum recording level does not reach the “0 dB”-level anymore. Finally I use the “amplify” effect to level the recording so that the maximum amplitude is at 0 dB.
Does anyone have an idea why the recording is so “overleveled” without reducing the video’s volume?
Thanks,
Manfred
