Recording at a slower or faster Playback Speed
I’ve been working with audacity for just a little while, but after looking around here, I haven’t found it.
I have been working with original soundtracks, and i noticed some sound more interesting when the playback is set faster or slower.
I want to record these soundtracks with the playback speed set (at say 0.70 or at 1.35). I know it should shorten or legthen the song, so is there instead a way to “stretch” or “compress” the entire sound track instead of recording it at a different playback speed?
Thanks for any feedback, and i wasn’t sure if this would be some kind of recording technique.
~Sevah
Use Audacity 1.3.5 and select “change tempo” from the effects menu.
Note that the more you stretch it, the worse the sound quality will become.
All right! Thanks alot! I actually found that instead choosing the Change speed instead of using the Tempo change is what i wanted.
Oh that’s good. There is very little loss in sound quality using “Change Speed”, since it’s just resampling and does not need to stretch the sound.
