Just got Audicity. Have over 100 albums to put on computer thru Audacity. Can I put all my albums on first and later do the editing.
Yes, you can save each one or each side after recording (“Export” as WAV).
Then you can open them and edit whenever you’re ready.
You might want to go through the whole process with the 1st album first to make sure everything is working and you don’t repeat some mistake on all of them.
I’d start with your least favourite albums first as your skills will improve.
I made the mistake of starting with my favorites and then found myself going back to do them over again later.
Peter
