Recorder track not aligned
Hi!
I’m using Audacity on Linux to record a new track over an existing one, using the line in input.
The recorded track is misaligned from the existing one, with an advance of 150ms…
I cannot understand, I could think of a delay, but in this case the record is in advance…
So every time I have to add 150ms of silence to the new track.
Any idea?
Thank you
Stefano
Once you’ve measured the latency of your setup, dial it in to Audacity’s latency compensation. One time only: set & forget.
