I remember Audacity forum’s members were more friendly and forgiving as it should be because there are people out there who aren’t sound engineer experts (like you seem to be) also people who have different language backgrounds and barriers.
As I said I think latency might be the wrong word, and you got the audio sample so what is the problem?
Sorry if I wasn’t able to describe the problem the way you loved to, perhaps you corrected the language part of my post but what about the real problem?
Just I want you know that Audacity is well known BUT right now there are too many free alternatives.
Yes I believe that might be the issue, but as you know and Audacity knows, setting Windows’ recording isn’t an easy task especially when we want to record live streaming.
This is a fresh new system and I had to find the way on how to abilitate the “hidden” stereo mix option then I followed the help document the same you linked but I still wasn’t able to find the solution.
Maybe I need to spend more time or just play with another free software.
I wish I used the correct technical language.
S’OK. We sometimes hit these things on a dead run and you get sandwiched between other posters.
Perfectly true. Recording sound on a Windows machine is a pain in the neck—largely, oddly enough, from the efforts of the Windows people to keep it from being a pain in the neck.
Windows stopped being general purpose machines a long time ago. They are corporate communication devices now and if that’s what you do with them, it’s just open them up and start working. It’s when you want to do something else that you have to turn off all the normal Windows stuff and turn on the stuff you actually want.
Does the work sound OK if you just flat, plain listen to it? Close Audacity. Get your headphones on and listen carefully to the sound clips. Are they clean? No echoes?
Latency is fancy for delay. If you record several different instruments over each other to form a song (called Overdubbing) and they don’t all line up to the beat, that’s recording latency and it’s adjustable.
Start Audacity.
Audacity > Edit > Preferences > Recording. Turn off everything in the Playthrough panel > OK.
Switch to the browser and start the music. Switch to Audacity and press Record. You won’t hear anything, but do you get the bouncing Red recording meters?
Do you hear the music and do you get both sets of sound meters? You shouldn’t.
Do that for a minute or two and Stop.
Play the track. You should be able to hear it in your headphones. Is it clean?
