record volume low
I am using a turntable and a EAS USB Audio Grabber with the latest Audacity and windows 10 on a HP Laptop. There is recording made but the volume is so low I can hardly hear it during monitoring and playback. I’ve set the volume levels I can find to the highest it will go but nothing changes. The blue line for the recording is flat lined.
A standalone turntable without USB connection?
How are you connecting the turntable to that EAS device? Does EAS provide phono pre-amplification and RIAA equalization? I have not found online that it does. If not, it is the wrong tool for the job and you would completely expect a low level recording, unless your turntable is part of a music centre or connected to a phono amplifier.
Also reviews of the device say it is low level even with a phono pre-amp: https://www.amazon.com/EAS-Digital-Converter-Systems-Cassette/dp/B013E21TUK#customerReviews.
You may want to look at a better device for the job such as ART USB Phono: http://wiki.audacityteam.org/wiki/Sound_Devices_and_Interfaces#USB_Interfaces.
Please always give us all three Audacity version numbers per the pink panel at the top of the page.
