record lps
hi
here is how I record lps with audacity adjust the playback moniters while playing the record…kepp them out of the red to avoid clipping.then record…stop after the recordings finished…trim the tune beginning and end…then hit select all…then hit the
effects then go into normalizing…let it process then file…then export then name the tune then put it on the desktop…now that’s how I do it…in this case I tried to adjust the playback moniters…when I think I do i record the record as above…hit the normalizer let it
process save it and at the end i see i have some clipping.its just happening with this one lp.all the others are ok.im using a windows
64 bit dell computer…thanks
lenny
