Hello, I use a Zoom H4n Recorder as an audio interface, plugged through USB. It works great with my BOSS RC-30 loop station plugged to both guitar and mic. I’ve Tried to add another mic to the second ZOOM audio interface INPUT, but Audacity can’t See it, iven though I’ve disabled the “MONO MIX” function. Please can You help me ? I would love to record main vocals on a separate indipendent track, simultaneously.
I don’t have a Zoom H4, but I would have thought that when using the H4 as a USB interface, that the Zoom would continue to use the external mic that you have plugged in. Perhaps your H4N manual can clarify that point.
Note that Audacity will not see the plugged in microphone as a new device. Audacity will just see the H4N (because that is the “sound card” device). Whether or not the H4N passes audio from an external mic to the computer via USB or whether it only passes audio from its built-in mics, is entirely down to the H4N. I would have expected that you could record from the plugged in external mic, but as I said, I don’t have an H4N to test.
Yes it works in audacity, but just using one of the two inputs (I send both guitar and MIC to the input of my loop station, and then the output of the loop station to ONE of the TWO inputs of the Zoom, and it works fine in audacity.
But when I’ve tried to plug another mic simultaneously in the SECOND input of the zoom recorder, audacity seems unable to record anything(either the previous well working one!)
Audacity can only record from 1 “device” at a time, but is able to record from as many “input channels” at that device makes available.
If you could copy and paste the information from “Help menu > Audio device info”, that may provide some insight as to how Audacity sees the H4N.
When I ran into this, it turns out Zoom means 4 channels by counting the two built-in microphones and two optional devices.
Optional Devices:
One XLR microphone and one guitar.
Two Guitars.
Two XLR microphones.
You never get two XLR microphones and two guitars.
Manufacturers do this all the time. My PV6, Six Channel Audio Mixer!! will only mix four microphones. The two guitar inputs brings the channels up to 6.
There you go.
!!! When you read “Altoparlanti”, it means “Speakers” in italian, I guess it refers to the ZOOM built in little speaker. It also has an audio output (that I send to the mixer, this help me to listen both backtrack from audacity and live mic input while recording)
I’m sending into the first optional device input, the output from the loop station BOSS RC-30 plugged to guitar and a dynamic mic, and I would love to use the second optional device input for the condenser mic, so I can record in audacity 2 tracks, one for the looped (guitar+voice), and the other one for the main vocals from the condenser mic.
Many thanks for your answer!
Th Zoom H4N is showing up as a 2 channel device with drivers support for MME, Direct Sound and WASAPI.
That means that, although the H4N is advertised as having “4 track” ability, the standard Windows drivers for the H4N support only 2 channels.
I believe that the Zoom H4N also supports ASIO drivers, but Audacity cannot be distributed with ASIO support due to licensing restriction.
If you plug your mic directly into the zoom, and your guitar into the other channel of the zoom, are you able to record on the zoom (as a standalone recorder), both the mic and the guitar?
If yes, then without changing anything else, connect the zoom via the USB cable to your computer and set the zoom to “audio interface” mode.
Open the Windows Sound Control Panel and ensure that the zoom is set for recording 2 channels stereo. Can you see the recording level meters (in the control panel) responding to both microphone input and guitar input?
If yes, launch Audacity, ensure that it is set to record 2 channel stereo in the device toolbar and make a test recording.
Can you show in the instructions where the H4 will act as a four-track USB device? My instructions go on for pages how you can use the four tracks internally for special effects and production. Also instructions how to mix down to stereo for delivery. No mention of delivering four tracks.
Even if H4 only delivers two tracks, it does not matter providing it passes an external mic when being used as a USB interface.
Koz, if CoreAudio only sees two Zoom recording channels in Audio MIDI Setup on OS X, then I assume that is all you get as an interface, unless there is some setting somewhere that controls that. CoreAudio should be as good as ASIO at seeing all available channels.
Following your step I’ve realized what an epic fail I’ve done last time!
I’ve forgotten to turn on the second line input on the zoom, I was sure that in “audio interface mode” you couldn’t press any button, so only the 1 was lightning in red!
I’ve press on the number 2 button as well, and it turns on, and it all works great!
You have to have both buttons 1 e 2 turned in red, and it works in stereo mode.
After the recording, I just need to split the recording in two mono tracks, and then duplicate each on into stereo track, I’ll figure out how to do it, I remember Audacity can do this.
Or it’s possible to set previously 2 empty recording stereo-tracks with auto-diplicate in stereo ?
You only need to “Split to Mono” unless you specifically want to apply a stereo effect. Mono tracks will play through both left and right speakers, though you can also “pan” them left or right if you wish by using the track “Pan” slider (Audacity Manual).
If a mono track is panned off-centre, then when you export as an ordinary audio file it will create a stereo file. If it is panned dead centre it will produce a mono file that will play equally through both left and right speakers.
I meant better then the device recorder support, who told me that it was impossible with audacity.
Ah a little question: How can I have a double headphone monitor from the mixer PHONIC MM 1002a ? I’ve tried with EFX OUT, Out Main, but it doesn’t sound good.
I would love that both singer and player can listen the whole live recording in their own headphone.
Something like this: Millenium HA 4 – Thomann UK
It’s called a “headphone amplifier”. You plug it into a normal headphone socket and it gives you multiple (in this case 4) headphone sockets with independent volume controls.
