Mastering indicated I should post a clip-on forum. Hard working novice trying to DIY narrate, wrestling with ACX qual. Much appreciate if someone could check it for me. TY https://audio.com/richard-smith-2/test-clip
There’s a noticeable constant hum @ 240Hz when you’re speaking …
Multi-view - Audacity ManualOddly it does not appear in your “silence” at the start.
IMO your background-noise, (computer fan ?, air-con?), is too loud for audio book work.
TY. I found and eliminated 4 likely sources. ACX Check now shows noise floor at -69.73 (without Noise Reduction). Here is another audio clip: https://audio.com/richard-smith-2/the-betrothed-2
I can hear a clock ticking, (it’s also visible on the spectrogram).
The main issue is the loud bassy resonance at 70Hz.
A high-pass filter at 100Hz 48db/octave gets rid of it …
IMO the equalization of your voice is near perfect.
Huge TY. You have a remarkable ear!! I thought the old clock was long dead.
