Audacity 2.0.5, Windows 7 X64
Goal: to stream white-noise-free audio from my desktop microphone(input) to Virtual Audio Cable(output).
I am able to stream audio by using Edit/Preferences/Recording Enable “software playthrough”, setting the correct input and output devices, and pressing record. However, I am unable to use the “Noise Removal” option while streaming/recording audio. Is there a way to have real time Noise Removal? (similar to the “Adaptive Noise Reduction” setting of Adobe Audition?)
Thank you for your help,
Gid
