Re: Yellow lines
Hi I am running the 2.0.5 version of audacity (Windows) and I am trying to cut and paste an audio file to make it say certain things. This is known as a YouTube poop. Anyway my problem is that if I’m trying to cut a clip that matches on the audiolines then it snaps my selection to it. I really need to turn this feature off please. All help is greatly appreciated.
This could be the problem: Audacity Manual
The “yellow line” snapping can’t be turned off, but it’s a “weak” snapping effect and if you zoom in a bit closer you will find that you can easily overcome that snapping.
Please don’t double post. It just wastes our time.
If necessary the topic can be continued here: https://forum.audacityteam.org/t/re-yellow-border-around-sections/31922/1
Topic locked.
