After exporting a recording from an LP to itunes it will not allow me to
put any artwork onto album part of itunes . Since I can do this with any
other recording I put into itunes it must be something in the audacity
program that stops me. Has anyone had the same problem?
Lots more details!
A WAV, 44100 Hz, 16-bit Stereo?
any other recording I put into itunes
Such as specifically what and from where?
IIRC iTunes has no facility to add artwork to WAV files - you need to convert to AAC or MP3 and then you can copy in artwork.
Have a look at this workflow from the manual - you may find it useful: http://manual.audacityteam.org/o/man/sample_workflow_for_exporting_to_itunes.html
Yes I think that is the correct answer. Try exporting to MP3 or AIFF instead. Also see:
https://discussions.apple.com/thread/4563471?start=0&tstart=0 .
Note that if you import any file format into Audacity that contains lyrics or album art, Audacity removes the lyrics or images on export.
