Pls help if you can. Regarding help for “another copy of audacity is already running.” If I click finder, there is no option for “Go> go to folder…” or any of that info that appears in the how to fix “another copy running” thread. There is no “~Library/support,” no “path” to paste. There is only , a list of recents, a list of applications and a list of documents etc.
Under “locations” audacity appears and if I click it, its the installer.
I can find the folder for applications support but Audacity isn’t listed.
After recording for 35 minutes I found the file corrupted. The blame? Same as others above, only after deleting and reinstalling audacity (mojave and AUD 2.3.3) I searched this ~/Library/Application Support/audacity/SessionData and got nothing. I went further and under the applications support, Audacity is not listed. There is no duplicate install of audacity, and all .aup files are gone. How can I find the lock file and delete it? Yes I re-started after the install.
Thanks for any help you can offer.
