rate shifter skips on audaicty 2.1.3 alpha
hi there, when i apply the rate shifter the song skips in certain area. you can see for your self. the rate shifter skips on the songs that i’m try to do with rate shift. can you please see whats wrong?
rate_shifter_1417.7z (27.2 KB)
It is a known limitation of the effect - please see http://plugin.org.uk/ladspa-swh/docs/ladspa-swh.html#id1417.
how do i correct this effect of the rate shifter?
If rate shifter does not provide the effect that you need, use a different effect.
For high quality stretching, use the “Sliding Time Scale / Pitch Shift” effect: http://manual.audacityteam.org/man/sliding_time_scale_pitch_shift.html
