I was going to ask folks here how to achieve an effect as tho someone was talking on the radio. I’ve heard this done a few times w/ various songs. However, I found a tut on Youtube so I thot I’d share it. http://youtu.be/zV9KyoV8h20. Enjoy.
–Allen
Very good. I wonder what she used for the capture.
Got me on what was used. By the by, those instructions are for older versions of Audacity. For 2.0 it’s even easier.
- Highlight the track you want to adjust.
- In Effect, select Equalization and be sure it is set on Draw Curves. (Click the Flatten button if you don’t have a flat line at 0dB.)
- Click the bluish line a 20 Hz, 1000Hz, 2000Hz, 8000Hz and 10000Hz and right end scale to form edit points.
- Bottom out all the edit points except the 2000Hz and 8000Hz.
- Drag the 2000Hz and 8000Hz points up to 12dB.
You can play with the envelope a bit to adjust to taste.
–Allen
Koz,
You could try Wink or CamStudio for screen capture.
–Allen
