Quick way to check Silence Finder splits??
Back when I had Windows, I could use CD Wave, which had among its transport controls a “>|”-type button which allowed quickly scanning a whole audio file to make sure all the split point labels had been properly placed, before going ahead and saving the results of the split operation. Does Audacity have a way of doing this? I just “Silence Finder”-ed a file into 21 labels and find myself wishing I had a quick way of checking them by ear. Thanks.
Click in or DOWN arrow into the label Track then TAB into the next label or SHIFT + TAB into the previous label.
When you have tabbed into the label, press the Play button, or using the keyboard, UP arrow then SPACE. DOWN arrow to continue using TAB.
Thank you!
