I’m editing, mixing two tracks - audience and main speaker. Two different mics.
The audience portions vary in terms of best quality between the two mics. What I’ve been doing is manually adjusting audience volume (most commonly increasing) with both amplify effect and envelope tool. Audience track often needs to fade in and out for seamless effect because I silence sections on audience vocals when they are not speaking
When the speaker is talking, need to lower the volume on audience track so that the better quality on speaker’s track is only audible.
So that’s the basic workflow. Everything manual with amp + envelope aside from compression + noise removal that’s already been applied.
Was looking for more effective/efficient way to accomplish same/better result. Any suggestions?
